I have owned this boat less than a year. Recently my shaft seal started to leak excessively. Tried to adjust and could not get the nut to move, the whole assembly started to move. I need help with several questions. Should I be able to adust the seals in the water? How about adding seal material? What kind of seal material in normal installed. Any help would be appreciate. If you have experienced this problem and have fouund a fix, that would be greatThanks
