John Killian
The local yard is replacing the shaft on my 1982 37 Cutter, they say that I should replace the metal tube that is through the hull where the shaft exits. The packing gland is mounted on the tube on the inside of the boat. They report some corrosion. I have never encountered this before, is it commom place to do? Any thoughts. Thanks, John Killian
