My shaft log is exposed bronze where it exits the hull, meaning it is without fiberglass wrap from the hull to the stuffing box. You could build it up with fiberglass to better fit your volvo shaft seal, but I doubt glassing  it adds much strength  past a few inches from the hull. If it were me, I would just keep it the way it is now. Makes it easier to inspect and  keep the bilge clean.       From: "maciek.k.lech@... [AlbinVega]"
AlbinVega@yahoogroups.com To:
AlbinVega@yahoogroups.com  Sent: Monday, June 26, 2017 10:05 AM Subject: Re: [AlbinVega] Shaft log wet/mushy.
      Yes indeed, I have a bronze tube. I assume the soft goo was a mix of fiberglass with grease.I cleaned most of it up, and it the fiberglass started to flake off.But no holes, yay! Here are some pictures, both before and after the cleanup, which might make it easier to explain:
 anyone else in here redone the log? Should I keep flaking off, and then re-glass? The diameter of the log is actually a bit too thin for the volvo penta rubber shaft seal, so adding 10mm while re-glassing for strength seems like a great idea.
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 #ygrps-yiv-339543870yiv9473375133 --
  #ygrps-yiv-339543870yiv9473375133ygrp-mkp {
border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 #ygrps-yiv-339543870yiv9473375133ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 #ygrps-yiv-339543870yiv9473375133ygrp-mkp #ygrps-yiv-339543870yiv9473375133hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 #ygrps-yiv-339543870yiv9473375133ygrp-mkp #ygrps-yiv-339543870yiv9473375133ads {
margin-bottom:10px;}
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 #ygrps-yiv-339543870yiv9473375133ygrp-mkp .ygrps-yiv-339543870yiv9473375133ad {
padding:0 0;}
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 #ygrps-yiv-339543870yiv9473375133ygrp-mkp .ygrps-yiv-339543870yiv9473375133ad p {
margin:0;}
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 #ygrps-yiv-339543870yiv9473375133ygrp-mkp .ygrps-yiv-339543870yiv9473375133ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 #ygrps-yiv-339543870yiv9473375133ygrp-sponsor #ygrps-yiv-339543870yiv9473375133ygrp-lc {
font-family:Arial;}
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 #ygrps-yiv-339543870yiv9473375133ygrp-sponsor #ygrps-yiv-339543870yiv9473375133ygrp-lc #ygrps-yiv-339543870yiv9473375133hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 #ygrps-yiv-339543870yiv9473375133ygrp-sponsor #ygrps-yiv-339543870yiv9473375133ygrp-lc .ygrps-yiv-339543870yiv9473375133ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 #ygrps-yiv-339543870yiv9473375133actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 #ygrps-yiv-339543870yiv9473375133activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 #ygrps-yiv-339543870yiv9473375133activity span {
font-weight:700;}
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 #ygrps-yiv-339543870yiv9473375133activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 #ygrps-yiv-339543870yiv9473375133activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 #ygrps-yiv-339543870yiv9473375133activity span span {
color:#ff7900;}
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 #ygrps-yiv-339543870yiv9473375133activity span .ygrps-yiv-339543870yiv9473375133underline {
text-decoration:underline;}
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 .ygrps-yiv-339543870yiv9473375133attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 .ygrps-yiv-339543870yiv9473375133attach div a {
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 .ygrps-yiv-339543870yiv9473375133attach img {
border:none;padding-right:5px;}
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 .ygrps-yiv-339543870yiv9473375133attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 .ygrps-yiv-339543870yiv9473375133attach label a {
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 .ygrps-yiv-339543870yiv9473375133bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 .ygrps-yiv-339543870yiv9473375133bold a {
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 dd.ygrps-yiv-339543870yiv9473375133last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 dd.ygrps-yiv-339543870yiv9473375133last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 dd.ygrps-yiv-339543870yiv9473375133last p span.ygrps-yiv-339543870yiv9473375133yshortcuts {
margin-right:0;}
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 div.ygrps-yiv-339543870yiv9473375133attach-table div div a {
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 div.ygrps-yiv-339543870yiv9473375133attach-table {
width:400px;}
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 div.ygrps-yiv-339543870yiv9473375133file-title a, #ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 div.ygrps-yiv-339543870yiv9473375133file-title a:active, #ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 div.ygrps-yiv-339543870yiv9473375133file-title a:hover, #ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 div.ygrps-yiv-339543870yiv9473375133file-title a:visited {
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 div.ygrps-yiv-339543870yiv9473375133photo-title a, #ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 div.ygrps-yiv-339543870yiv9473375133photo-title a:active, #ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 div.ygrps-yiv-339543870yiv9473375133photo-title a:hover, #ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 div.ygrps-yiv-339543870yiv9473375133photo-title a:visited {
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 div#ygrps-yiv-339543870yiv9473375133ygrp-mlmsg #ygrps-yiv-339543870yiv9473375133ygrp-msg p a span.ygrps-yiv-339543870yiv9473375133yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 .ygrps-yiv-339543870yiv9473375133green {
color:#628c2a;}
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 .ygrps-yiv-339543870yiv9473375133MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 o {
font-size:0;}
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 #ygrps-yiv-339543870yiv9473375133photos div {
float:left;width:72px;}
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 #ygrps-yiv-339543870yiv9473375133photos div div {
border:1px solid #666666;min-height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 #ygrps-yiv-339543870yiv9473375133photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 #ygrps-yiv-339543870yiv9473375133reco-category {
font-size:77%;}
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 #ygrps-yiv-339543870yiv9473375133reco-desc {
font-size:77%;}
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 .ygrps-yiv-339543870yiv9473375133replbq {
margin:4px;}
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 #ygrps-yiv-339543870yiv9473375133ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 #ygrps-yiv-339543870yiv9473375133ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 #ygrps-yiv-339543870yiv9473375133ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 #ygrps-yiv-339543870yiv9473375133ygrp-mlmsg select, #ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 input, #ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 #ygrps-yiv-339543870yiv9473375133ygrp-mlmsg pre, #ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 code {
font:115% monospace;}
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 #ygrps-yiv-339543870yiv9473375133ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 #ygrps-yiv-339543870yiv9473375133ygrp-mlmsg #ygrps-yiv-339543870yiv9473375133logo {
padding-bottom:10px;}#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 #ygrps-yiv-339543870yiv9473375133ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 #ygrps-yiv-339543870yiv9473375133ygrp-msg p#ygrps-yiv-339543870yiv9473375133attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 #ygrps-yiv-339543870yiv9473375133ygrp-reco #ygrps-yiv-339543870yiv9473375133reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 #ygrps-yiv-339543870yiv9473375133ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 #ygrps-yiv-339543870yiv9473375133ygrp-sponsor #ygrps-yiv-339543870yiv9473375133ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 #ygrps-yiv-339543870yiv9473375133ygrp-sponsor #ygrps-yiv-339543870yiv9473375133ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 #ygrps-yiv-339543870yiv9473375133ygrp-sponsor #ygrps-yiv-339543870yiv9473375133ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 #ygrps-yiv-339543870yiv9473375133ygrp-text {
font-family:Georgia;}
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 #ygrps-yiv-339543870yiv9473375133ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 #ygrps-yiv-339543870yiv9473375133ygrp-text tt {
font-size:120%;}
#ygrps-yiv-339543870 #ygrps-yiv-339543870yiv9473375133 #ygrps-yiv-339543870yiv9473375133ygrp-vital ul li:last-child {
border-right:none !important;}
