I need to replace a very badly corroded shaft coupling on my Hunter Vision 32. The current setup has some unknown brand of flexible shaft saver and a 4" diameter coupling on my 1" shaft. The coupler has a through-bolt and I don't think it is keyed (if it is keyed, it is corroded so badly I can't see it!)
I can't seem to find an identical coupling anywhere .. does anyone have suggestions where to find one?
Also .. am I nuts for trying to do this myself? I need to get the coupling off in order to repack the stuffing box. Local Marina will put me in the sling and leave me there over the weekend so I can work out of the water at a more liesurely pace.
Question about the through-bolt ... my plan is to hacksaw off the nut(s) and/or bolt head to get the through-bolt out. Are there any threads inside the coupling that would make that a dumb idea to try? Then the plan is to remove the shaft saver and use a long socket against the shaft and draw the coupler off the shaft by using longer bolts to the engine side coupling.
I'm considering installing a PSS shaft seal ... but there is barely 7" from the end of the coupling to the shaft bearing exiting the boat. Comments??? I'll also call PSS ..
I've got a case of PB Blaster ;-) and have already started application
I'd be grateful to hear from all the experienced folks as to whether #1, I should try this myself at all, and #2 any tips / tricks / caveats / preparations to make etc.!
Thanks!
Thanks!
