Hi everyone
We were able to cut off the coupling. Ordering a new one. My friends insists that I should not bother with fit and facing to the shaft. He also insists that I should not worry about having the shaft worked on at a shop. I want your opinion on this. The engine was moved to accomplish all this.
Another question regarding the stuffing box: what was removed appears to be from a special kit of some sort. I expected to find flax rings. I found cloth type rings separated by metal and plastic washers, still in good shape.. Does this make sense to anyone? I am new to sailing, easy to guess, and want to make sure I am doing the right. Should I just replace everything with flax? reuse the washers in between? THANK YOU SO MUCH
