A
Allan Hadad
I am currently hauled out for a bottom job, and other tasks that can't be done while in the water. I just finished replacing all four motormounts, the cutlass bearing and am attempting to install a PSS dripless shaft seal. My dilema is that the shaft is rubbing on one side of the stern tube. I can also see that the rubber in the new cutlass bearing is compressed at the forward side of the strut and at the bottom on the aft side. Apparently there is some misalignment. Has anyone had this same problem? I don't know if I can shim the strut, or elongate the holes in order to move it around. The strut is beveled so it fits tight into the recess under the hull. How is it possible to change its orientation? Any assistance would be appreciated.Allan
