The Rest of the Story........
Okay, so I see a missing bolt that was off the mounting bracket portion that held the engine bracket in place. Strange I thought, so I went out to a hardware store and bought a new one (15/16th). After replacing it I made the unfortunate mistake of tightening them all down, hence the shaft alignment goes south!! How dumb!! At 1100 rpm the vibration kicked in.Now, be advised that the Catalina 30's engine is mounted amidships and is easily accessible on all four sides. Standing over it, all four mounting bolts are observed. No body contortions here!. I try an experiment after reading dozens of responses on shaft alignment.With my wife at the helm, I attach additonal spring and aft lines and I take off the alternator belt to avoid any dangers at that part of the engine. At the dock in forward, my wife revs to 1100 rpm, the vibe kicks in and I proceed with a long extension and socket to go around and adjust the mounting bolts here and their in random sequence just to see if that indeed makes a difference. Well, my efforts payed off as we managed to smooth it out to 1800 rpm. To get it to the higher rpm range requires a trip out on the lake, if I decide to do that. The wake we created was getting abit ugly despite it was early morning on a weekday and no one was on their boats or on the docks.So, their is something to say that adjustments can be made with the engine running providing you feel you are safe (deep socket, extensions and accessibility were key)and perhaps lucky.The surveyer who provided me the, "loosen then run then tighten", advice has been surveying for over 35 years, has one of the best reputations in Georgia and has done this dozens of times and claims it is effective. Who's to argue? I do not think he would recommend this without having the experience to know better. What I worked fine to get me out of the dock and at cruising speed without any problem. I do want though to be able to wind her up to 2300+ rpm to ensure all is balanced. Interesting topic.BobCatalina 30
