sewage pump out question..
roy
Feb 1, 2009
186
2 270 soldiers point
Hello all,
I've never had a pump out before, and I am working on installing my head. So,..
Is it a pump out nozzel or hose?
Is the nozzel or hose flexible or rigid?
I am planning to install the KISS system and am wondering if I need a perfectly straight shot from the pump-out hatch to the Tee or Y fitting at the ball cock thru hull.
Thanks,
Roy_______________________________________________
Join Excite! - http://www.excite.com
The most personalized portal on the Web!
Dec 11, 2007
179
- - port st. lucie,fl.
Roy-
The pumpout system is by vacuum. They hook up a nozzle to your
pumpout fitting on the deck and suck it out. Your internal hoses
need to be rigid enough to withstand the suction. That is all.
Richard V1812
Oct 30, 2019
1,459
Roy,
I tried to answer your email but it bounced.
The eyes in the face of the tank don't work. I guess the epoxy is not
clear enough to see through. I just got home from a 20 day trip, and
find that I can gauge the level of the tank by the sound of the water
when flushing.
On your pumpout line: make sure the hose or pipe goes almost all the
way to the bottom. Mine is about 3/4" from the bottom, inside. You
also need to have a vent, or better still two vents, so the tank will
not implode when being sucked out. I used a couple of 5/8" ID fuel
tank vents, one on either side of the head window.
I've never used the pumpout feature yet as I managed to get far
enough offshore to use direct discharge.
Peter
#1331 'Sin Tacha'
May 30, 2006
1,075
Thanks Peter.
I do wonder if there is a passive way to see the level of waste water in the holding tank?
Maybe cut some type of vertical slot in the surrounding support wood?
A removeable pannel?
Roy
