Severn Inflatable
Apr 29, 2012
224
Beneteau 35s5 bristol ri
I have a 1996 Severn 10ft RIB that has a slow leak. I think it may be the valve. Does anyone know the procedure in replacing or repairing the valve?
SFS
Aug 18, 2015
2,091
Currently Boatless Okinawa
Google search is your friend. Lots of threads on various forums on this topic.
Parts are not impossible to find, even if it means upgrading the valve, and patching the new one in after cutting out the old one. Before you go that far, check the valve itself. Some valves have inner portions that can be unscrewed and replaced, without taking out the whole outer valve body.
Having said all that, first you should make absolutely sure the valve is really leaking. Many valves have a pin in the center with a spring attached to it. Make sure the pin is not locked (via turning it) into a position where the spring holds the valve open. You wouldn't be the first person to make this mistake.
Aug 17, 2013
1,278
Pearson P30 202 Ottawa
soapy water in a spray gun is your friend, spray the boat and look for bubbles
Apr 29, 2012
224
Any advice on finding the right wrench for removing the inner valve?
