A couple of times I have been over canvassed going to windward with two reefs in my newish Dacron main sail with my also newish furling headsail partly furled (with foam luff so works well when partly furled).
So for about Euro 150 I had a third reef added by a well regarded sail maker. Reefing cringle, reef points for laces and reinforcements in sail.
I have "slab" reefing.
So to the point, I plan to use the first reefing line to put in the third reef on the rare occasions when it is needed. Keeping the second reef in place. Unreaving the first reefing line and passing it through the 3rd reefing
outhaul on leech of sail and back to turning block on boom and forward along boom to cleat. Of course the reef ring/cringle on tack of sail is hauled down to a snap hook at the goose neck.
(I've read that this is often done with slab reefing to avoid having a permanent reefing line for the rarely used third reef?)
I tried this today in light airs to check that the lines ran ok. All went fine.
Of course the leech of the sail is outhauled using the turning block (intended for the first reef) at aft end of boom. So the leech cringle is outhauled fine but the reefing line is almost horizontal so leech of sail at third reef isn't pulled down onto boom.
Maybe this doesn't matter? I thought of lashing the reefing line down to the boom just aft of the leech cringle when I use the third reef "in anger".
Easily done with a (say) 5 metre 5mm line with a loop at the end. A few turns around the boom and job done.
I'd be grateful for comments. Am I overcomplicating this? Or have I missed something?
Thanks. John V1447 Breakaway
