jack
I need to adjust the knotmeter on my Catalina 27 {paddlewheel type}. Hull speed reads 7.4 when motoring at full thottle and the hull speed is 6.3 so I am thinking it's off a bit. There is a screw on the back of the meter for adjustments so I was thinking of running the boat under power at full thottle and adjusting the screw back a little to read 6.3 knots {hull speed}. I will take currents and tides into consideration while doing this. My question is, is there a more accurate way of doing this with out a gps? As always, thank you for your help and ideas, Jack
