Well, you know how you have all those jobs that need doing on the boat and how some seem such a can af worms that you figure, if you leave them long enough, they will go away? Well they don't.:cry:
I have been trying to take the standard jib off my CDI furler and replace it with the 150% genoa. However a few things don't seem to be adding up.
Sliding Luff up Forestay to adjust turnbuckle
Most people say you have to take out the cotter pin in the side of the extension on top of the black plastic furling drum in order to slide the drum up the luff extrusion. I have about 160mm of 'spare' forestay between the top of the luff cap (offically refered to as the Halyard Top Fitting or HTF) - see photo. I can slide the drum & luff up the forestay enough 'as is', to adjust the turnbuckle, without have to take out any pins. This concens me because, although I have had no problems to date with the furler moving up the forestay whilst under way it appear to be only a matter of time. Am I missing some mechansim that locks the plastic furling drum into the S/S outer cup?
Turnbuckle Type & Pinning it
The CDI site talks about pinning the bolts (threaded rods) in the turnbuckle but mine don't appear to be pinned. The CDI site talks about using "cotter pins", what we down under refer to as "split pins" <http://en.wikipedia.org/wiki/Split_pin> . Am I talking the correct language here?
They would have to be mighty small pins as one rod has a 5/64" hole and the other is a fraction less 5/16" but bigger than 1/16"?? - strange as that does not eveen correspond with any standard metric size?? - I suspect about 1.9mm??
The CDI site say "you may NOT use a 3-piece Navtec turnbuckle" but mine is branded Navtec - see photo. I cannot see why the current turnbuckle does not suit as the top threaded rod is roller swaged to the forestay and the bottom threaded rod is a T-rod and is fasted onto the S/S drum with a saddle arrangement. Having done a web search mine appears to be Navtec part no. 673-1/4-3 on the Navtec website as follows: http://www.americanriggingsupply.com/Navtec_Turnbuckles.pdf . The barrel is stamp on the middle bar with 'Navtec' on one side and the letter 'A' on the other side - no other ID markings.
I am unsure weather CDI mean 'don't use a Navtec turnbuckle' or 'don't use a 3-piece turnbuckle' and in either case I cannot undestand why?
