I just replied to another post recommending this product (
Dow corning 111) for use in lubricating a manual head. its a very good quality item that has several uses including lubricating ball valves. the product is an industry standard for many applications and i keep a good supply on my work trucks (and boats)...
if the boat is out of the water so you can get to the ball valves properly, the lubrication intervals will last so much longer.... it retains is consistency over a wide temperature range, so in the winter it wont cause the ball valves to stiffen up and make them hard to turn...
but if the boat is out of the water, you may want to take a solvent like wd40 and spray the valve.. work it open and closed several times and spray it again... this will dissolve any gummy deposits that sometimes cause the valves to work so hard...
then let it dry completely before applying the Dow 111....
