The only parts that I know of for a Merriman Pedestal is the plastic band, or whatever it's called that goes around the upper part of the pedestal and supports the throttle and shift lever (at least on my 1986 H28.5). There is a maker in Canada who makes this part out a aluminum and sells it for around $170. Email me, or search the HOW archives, if you need the address.
As to maintaining the pedestal, I assume you mean the steering gear inside it? I lube the chains from the top and bottom with common motor oil or machine oil. Be careful not to drip some on the throttle cable, as I did.... The throttle will slip forever more. On the underside, lube the turning blocks and wire cables with the same oil. Put some oil on a clean rag and run it along the cables to both oil them and check for burrs. Also, inspect the two quadrants around which the cables go. On my boat, I was astounded to find two small hairline cracks forming where these plates connect to the rudder stock. I then took the plates off and had them professionally welded.
