I discovered a buckled crack in the floor liner of my 94 C30 next to the nav station. Upon further investigation I found broken tabbing under the forward section of the after berth, more cracks in the liner in the same general area and some serious oil canning on the starboard aft cradle pad. I believe this is the original C30 cradle. I see a small amount of oil canning on the port side pad as well. I initially suspected that the keel didn't have enough blocking on the aft side.
I talked to the yard and they stated that it's not uncommon to see this with the Catalinas. He said that the factory cradles are too short (not sure how a longer one with the same number of pads would help) and that next year I should request stands instead. There's literally no bracing or a bulkhead where the pad touches. Just a little bit of tabbing to the floor liner. The yard said they would add four stands to the stern, pull the pin on the cradle pad and let the hull relax for a while. Their interim solution seems reasonable but I still suspect that the blocking could have been better.
Oil canning looks worse in person than in the photos. Does anyone have any thoughts on the current situation and future prevention?
