So I'm sure others have been here. You get your first boat, you have a couple of great days on the water, or at least you made it back with out a knock down.
Now your ready to completely gut your boat split the hull and deck joint and get that puppy cleaned up and painted.
The question is should you go through with it? Has any one done it? has any one made it through a hull/deck separation and live to talk about it?
I have a 1970 Venture 22 hull ID 316.... no is it 319........ 3something
It has leaky windows, leaky deck/hull joint, needs bottom paint, hull paint, interior sanding and paint, deck hardware needs to be re-bedded. I'm sure there's more but you get the idea.
I'm hoping to take it to a local yard and get some expert advise this week.
Some direction in what I'm going to do with this boat.
Admittedly, and I guess obviously I can continue to patch it up as I go but I don't really want that. I want everything to be clean and smooth I want to be starting from square one not from behind the 8 ball!
I really did give it try!!! I tried to just sail the boat and not worry about how see looks I tried to not look at the stripped down interior the horrible cover up of old failing paint. The bilges that have never seen a drop of paint.
I tried to leave it all alone but you cant really do that with a sailboat can you? As a sailboat owner you have to fix things constantly. new lines or halyards leak here or leak there. lights not working, sail needs stitching.
So why just go half in?
Its just not who I am!
So Unless someone has some reason why I should not do it..... It looks like this could be my total refit thread. At least I think thats what you call it.
