Tony Kriz
I have two (2) separate batteries on my H320 using a 1-2-Both switch. The starting battery is connected to the #1 switch position, the house battery is connected to the #2 position. Both batteries are connected separately to the altentor and battery charger but the batteries are connected negative to negative terminal - Why?I want to add an additional battery to the house bank in parallel to the current house battery but am not sure exactly how to connect them since it appears the current batteries are already connected.Do I keep the starting battery (#1) and the house bank connected by negative terminals? Should I add an isolator or combiner between the two house batteries? I've reviewed the archives but can't find an "obvious" answer to my question(s).I'm obviously not a battery expert and appreciate the help in advance.
