Those of you who have added a battery monitor shunt and/or a temperature sensor for your battery charger: How did you run the sensor cables to the battery area? Our 2000 (#31) C310 has two PVC pipes running under the head floor. Positive cables in one, negative in the other. There are fewer cables in the negative pipe, so that's plan "A". Any tricks to getting the phone jack connectors (Victron monitor and ProMariner charger) through without any damage? Did you pull the 1/0 wire out to make room and put it back later?
