Self tacking ...
I have a self-tacking staysail, not a jib, but the same will apply.Disadvantages:1. You are limited to a 100% foretriangle2. Without an auxiliary boom the set/shape will suffer (draft position) on all points of sail other than beating /close-winded. 3. When reaching, the head of the sail will be overtwisted (flapping) and the foot overtrimmed (too close to the centerline) unless re-sheeted to the rail or the boom is vanged to the deck/rail. The alternate is to apply a radial bend traveller (center of traveller track circle is the tack of athe sail) 'across' the deck; but then, you need a multiposition 'clew iron' to be able to set the correct for/aft 'fairlead' posiition. A "hoyt-boom" (or a boom that is prevented from rising) will solve 95% of these 'problems'. Otherwise without a boom, there will ALWAYS be for/aft fairlead position 'problems'. 4. a jib boom will sweep you off the foredeck if it gets 'loose' in a high wind. Advantages:1. Single line sheeting (with jib-boom).2. No need to change from windward/leeward sheets when tacking3. Hands-off operation when tacking on equal angles4. Easy way to 'blade' the jib in rough/high wind for boat control. Take a look at the hoyt-boom (offered from Forespar as a retrofit). The Hoyt-boom is standard equipment on Alerions and Island Packets. The obvious limitation is that you are restricted to less than a 100% foretriangle. If your boat is a 'fractional rig' this is not a problem; but, a masthead sloop will suffer large performance loss if limited to a 100% jib. hope this helps.
