G
Glenn Smith
I have a problem With my self bailing cockpit draining on my Catalina 22.I have clean both cockpit drains and have take the scupper valve off and cleaned, but water from cockpit will not drain out of valve.is it possible the the scupper valve is bad ,The way I understand how the valve works is water will drain out and not in. (Works as a check valve). Thanks Glenn Smith
