Selden Mast
Dec 4, 2003
90
Hunter 356 sandusky ohio
I have a Selden In-Inmast. When I reef my sail, it slowly creeps out and I have to start all over again. Any advice
Sep 20, 2006
155
Hunter 49 Mystic CT
Lock the gear on the mast. It's there just to prevent what you discribed
Sep 20, 2006
2,912
There is a lever on the winch on the mast. "Ratchet and Free" I think. Put on ratchet, it locks the winch and furler.
Dec 4, 2003
90
Thanks guys, I knew about the locking pin, I was hoping there was something else I could do because as you know when you have to reef the conditions are dicy and going up to the mast locking the pin and then coming back to the cockpit and if you have to reef even more you have to repeat the process.
Feb 14, 2014
7,437
Hunter 430 Waveland, MS
Staying in the cockpit is rough seas is a good thing.
I can clamp down or belay the Furling and Outhaul lines from the cockpit.
If you can't, I would also suggest Belaying both those lines, clockwise on a nearby winch, from within the cockpit.;)
Safe sailing...
Jim...
Dec 19, 2006
5,812
Hunter 36 Punta Gorda
I rap the 2 furling lines around the winch real tight and used this way in very high winds and have the problems.
I have never locked the winch up at the mast and if this does not work check for slippage from
worn furling line.
