Hi All,I'm getting close to installing my shiny new shrouds and stays. The fine riggers were kind enough to send along some seizing wire for the spreaders, but I am not sure what the proper procedure is for seizing. As some of you may remember from one of my previous posts, a po had used some stiff wire from some conduit for that purpose. This new wire I have now is stainless, fairly flexible and thin, and I gather that your supposed to wrap a few times between spreader and shroud, but how do you then affix it so it does not "unravel". Tie some sort of knot? Maybe twist the ends together, securely tape it (probably not a good idea depriving stainless of air)? Hopefully this is not too stupid of a question, but I can't seem to find any info on it. It's definitely a safety issue and I don't want to do it the wrong way. BTW- if it makes any difference, I will be covering the tips with boots.Thanks to all in advance - Manny
