seized stuffing box
David
Just put my boat in the water and noticed excessive leaking from the stuffing box. Couldn't break free the lock nut, I used pipe wrenches and muscle without any luck, are there any tricks to loosening them? Thanks
Feb 17, 2006
5,274
In the Lancer Forum on this site...
There is a thread about just that very thing. You might want to give it look and see if it can help. Maybe different tools might be the answer.
F
Fred
They can be hard to turn and hard to get at
The main "trick" is to be sure to use two wrenches so you are loosening the lock nut from the main nut, rather than putting the strain on the nuts or tube the stuffing box is attached to. An electric heat gun on the nut might help. Red ATF is (I say) as good as any other penetrationg oil. Try a few drops of ATF and the heat gun. I have also found that threats and strong language assist in these situations.
CalebD
Jun 27, 2006
1,479
Tartan 27' 1967 Nyack, NY
Coat the bolts with PB Blaster or equivalent
and let it do it's thing for a few hours and try to tighten the stuffing box a tiny bit first. If more water comes in or there are scraping sounds or vibrations coming from the engine/stuffing box area then you really need to re-pack your stuffing box soon before the bilge pump gets overwhelmed and batteries fail. The link below is for the packing material that has worked well for me 3 years so far and has required little or no tightening since I replaced it. Keep in mind that this is only normal maintenance of a sailboat with an inboard motor boat similar propulsion so dont panic. Just figure out what you need to fix and make the repairs yourself. You will learn a lot in the process as well. Fair winds. CalebD
abe
Jan 2, 2007
736
- - channel islands
Brian D, that was a great find.....
you can read about doing this stuff, but those pictures from Lancer really puts everything together. I now feel comfortable re stuffing next time i need to. abe
CalebD
Jun 27, 2006
1,479
Fred is right about the cursing thing
with stuffing boxes! They are always awkward to get at. Curses definately help!
W
Waffle
PB Lube Penetrating Oil and
pipe extensions on the wrenches. You'll need lots of muscle too!
Mar 21, 2004
2,175
Hunter 356 Cobb Island, MD
And BLOOD needs to be given....*yks
One must always bleed to appease the gods... Jim S/V Java
W
Warren Milberg
Here is a trick...
to loosen a frozen stuffing box when all the other stuff has failed: whack the lock nut on a flat with a ball peen hammer (in the direction you want it to move). You will not crack it or the shaft log. This will break the crud free. The first couple of times I did this it was on someone else's boat and I feared doing damage. Worked like a charm. If you try this method, post a follow-up as to the results.
And when you're ready to put it back
slather the lock nut facing with the box with Lanocote and you shouldn't have the problem ever asgain. Do the threads, too.
