Hi all!
In the process of restoring a 79 H33, I came across a very soggy section of deck over the head. Apparently the previous owner had installed a solar powered vent fan without properly sealing the wood core around the hole. Though drilling test holes around the opening, and by scraping out the goop that was once a wood core, I find that the rot goes about four inches back from the opening (almost full circle).
Now, I know the usual route here is to cut out the top layer of glass, replace the wood core, then replace the top layer of glass, but I was thinking that maybe, if I gave it some time time to dry out I could simply fill the void with "Kitty Hair" or similar filler. I really would like to avoid all the cutting and reglassing if possible.
Any thoughts? Thanks!
