I;m having trouble finding a secondary fuel filter for a Nanni Diesel 4180. The only number i have off the element is 10812. If any body has found these or knows of a cross refrence it would be great. Thanks
I recently went through the same process with some old Frams. And like you, had a real problem finding a secondary. Found them at NAPA auto parts. They have a really good cross reference book. Much cheaper too, than from a boat place. Give NAPA a try. I tried Advanced Auto Parts, O'Reily and Auto Zone first, because they are closer to me, but the only one who could find what I needed was NAPA.
Have a look at Cummins filtration (formerly called Fleetguard.I did a search by make and model and came up with the numbers shown below.Try the same search using the link given.You could then call the local Cummins distributor and see if they are in stock.I am not sure of your location or I would have given you a phone # to call.Regards.Application Lookup Results To view part details, click on the desired part number. To save results to a Product Worksheet, select each desired item, and then click Add to Worksheet.Add to Worksheet Part Type Part # # of Parts Required Manufacturer Lube, Spin-On LF3376 1 FLEETGUARD Note: FLEETGUARD LF3376 replaces OEM part NANNIDIESEL 970603003. Fuel, Cartridge FF146 1 FLEETGUARD Note: FLEETGUARD FF146 replaces OEM part NANNIDIESEL 970652307. Add to Worksheet
