Second hand transmission Hunter 31 1986
SeanP
Jun 6, 2017
87
Hunter 31 Portland
Hi,
It turns out that the chatter I am experiencing underway is due to a worn transmission (so the yard tells me). A new gear box is not available in the US and they are checking with Japan.
I thought one of you might know of where to hunt down a good condition used gear box as an alternative.
Cheers!
Sean
Jan 30, 2012
1,154
Nor'Sea 27 "Kiwanda" Portland/ Anacortes
What is the make of the motor, the transmission type and model number? There should be a label glued to the bell housing.
@SeanP it may be the damper plate. Still requires transmission removal to repair. Often a new plate can stop the rattle sound. But if you have the transmission removed, like they say in for a penny in for a pound, might just as well have it serviced.
SeanP
Jun 6, 2017
87
Hunter 31 Portland
Hi the motor is a Yanmar 2GM20(F), and the transmission is Kanzaki, KM2-C, ratio 2.62. Thanks!
SeanP
Jun 6, 2017
87
Hunter 31 Portland
Hi John, when I hold the drive shaft while in gear at idle, I can hear/feel the chatter...would this occur if it was just the damper plate?
SeanP
Jun 6, 2017
87
Hunter 31 Portland
Thanks Pateco, saw that one just now and there is another one that is new. Spendy, but at this point after replacing engine mounts, prop, shaft, cutless, and dripless seal, there is nothing left I can do ;)
Cheers,
Sean
Jan 30, 2012
1,154
Yours is a C - not a P so be sure the seller guarantees KM2P is interchangeable with your C model. Among other things there are three different gear ratios in this transmission.
Before you commit to a replacement, note that the C version is susceptible to clutch cone glazing. It is possible that all you need is to lapp the clutch surfaces. So make sure to diagnose yours before you go for a replacement because if lapping the clutch cone surfaces is all that is needed - and it frequently is - your fix will be way cheap.
Some tips - the transmission separates from the motor block with 8 bolts but it is almost never so simple. The splines in the dampner are frequently rusted to the output shaft. Replace the dampner too. It is a bit much price wise but a fail of the old one - usually broken springs - will be very disappointing. When you reassemble - spray paint the dampner both sides so the springs don't rust. You can rotate the springs to get good coverage. The dampner plate goes only one way - it will bind if you put it in backwards. Apply antizieze to the spline socket and the shaft. Use guide pins in the top two holes of the block. The splines will line up and the transmission will slide in place perfect.
I am in Portland OR. Call if you need any help. Assuming we are in the same Portland if you want to visit my place I can show you all of this stuff
Charles
SeanP
Jun 6, 2017
87
Hunter 31 Portland
I am in Portland so call if you need any help.
Charles
Hi Charles, very helpful thank you! The seller is not sure if the P is interchangeable with the C, so will play it safe. I am on Hayden Island....where are you in Portland? Would love to chat via phone if you had a few minutes?
Thanks!
Sean
Sep 11, 2015
149
Hunter 31 Marina del Rey
I have one available for sale. My story is that my 2GMF failed (slipped a bearing), so I bought a second hand 2GM20f that I installed in the boat. The 2GMF transmission was just serviced, so I kept that one. Now the flange that attaches to the motor is different between the 2GMF and the 2GM20f, so what I have available is a 2GM20f transmission attached to a 2GMF flange. If you want to use this transmission you will need to attach it to your existing flange. It is not a big job, just eight bolts and some sealant (no gasket needed). Let me know if you have questions or you can send me your flange and I can mate it for you. However, I advise you to do it yourself, it is a good learning experience and you get to see the internals of the transmission which is cool.
The gear ratio is 2.62. I would part with it for $1,000 bucks plus shipping (it is not light). By the way, I have the rest of the motor in parts, if anyone needs some (fuel pump, heat exchanger, the block, the head (serviced), injectors, etc.). I was keeping it for spares but the current motor has proven to be quite reliable, so I do not need them anymore.
Jan 30, 2012
1,154
If your story involves a 2GM then your transmission was probably a KM2-A. If so that is not what the OP is after. Can you tell him whether the transmission is (KM2) A, C, P, or P-1?
Otherwise as to the the bell housing (maybe what you call a flange - it is not clear) can you say if it is an A housing or the later C type housing?
The central question here is really what is the transmission you offer for sale. You describe it as a 2GM20 transmission but is that a C, P, or P1?
Charles
149
The transmission that I am selling is a KM2P. This is what is says on the back of the bell housing that came with the transmission. The transmission that I installed on the my 2GM20f is KM2-A. They are interchangeable as long as the bell housing (sorry for the confusion) is changed as well. As I described above, on the picture you see a KM2P transmission mated to a flat bell housing, probably referred to as type A housing.
SeanP
Jun 6, 2017
87
Hunter 31 Portland
Quick update that involves two of these wonderful forum members. After a call with Pizzazz, he offered to ship me his transmission unit from LA with the understanding that if it worked, I would pay him (+shipping) and if it did not, I would return it to him and cover all shipping costs. So considerate.
Charles came over to my boat no less than four times. On his first visit he painstakingly inspected every possible cause for my intermittent drive chain clatter. He changed the oil, adjusted the gear shift, ensured the drive shaft was centered, separated the coupler and rotated the one plate by 90 degrees and refastened it.
On his second visit we took the boat out for a test drive. All was going well with the boat moving well at 3000 RPM. Suddenly there was black smoke billowing from the engine compartment. We gingerly crept back to the dock to inspect the damage. Charles took all the battery cabling out to find that through chafing, the ground cable had shorted on the positive cable from battery #2. Over the next two visits he ran fresh cables and installed post-mounted 200Ah fuses on each of the three batteries. Everything was properly routed and protected with conduit.
I am stunned at the kindness of both Pizzazz and Charles for helping me out! I will certainly pay it forward. I look forward to finally having a leisurely sail with Charles when he is freed up from installing a motor on his own boat this summer!
Thank you Pizzazz. Thank you Charles!
Best,
Sean
SeanP
Jun 6, 2017
87
Hunter 31 Portland
Hi Chip, I have finally restored the instrument panel and protective sleeving to all cables are Charles helped me with the major re-cabling work after the fire. With this done, I can finally take her back out for another test. Stay tuned...thanks for checking in!
Sean
