Seatalk cables
malexander
I want to make my oun Seatalk cables.
Does anyone know for sure what size the connectors are.
I am thinking they are .125 pushons, but could they be 3/16"
Mark Alexander
Catalina 350
Kerr Lake NC
Beneteau 323 Annapolis MD
I have one of the 3-way hubs and a cable here, and they mic at 1/8. Be gentle when you push them onto the males.
Jun 6, 2006
6,990
Unfortunatly they are aranged in an arc and have a propriatary plug. so while you could certianly make a wire loom the cable end would have to be a Rube Goldburg affair with either goop or epoxy.
Unfortunatly they are arranged in an arc and have a propriatary plug. so while you could certianly make a wire loom the cable end would have to be a Rube Goldburg affair with either goop or epoxy.
The plug is not needed. There was way too much wire in my nav pod, so I took out the Seatalk cables and bridges and did what the OP is trying to do.
Jun 6, 2006
6,990
Well OK, I'd think you would want to at least squirt in a slug of silicon into the plug hole after wiring to keep accidental movement of the wires from causing a short. you could alternatly shrink wrap each wire.
May 28, 2009
764
Hunter 376 Pensacola, FL
I ordered a bag of 100 of the .125 push ons for like $5 or so on ebay, and they work, but they are a TIGHT TIGHT TIGHT fit. I called Raymarine, and they sold me a set, I think there were about 8 or 10 in the package, but by the time you figured in postage and all, it came to about $20. But they fit better. The guy I talked to said they got them from the UK, so they might actually be measured in millimeters. .125 inch just happens to be the closest American measurement.
