Kimmo, generally speaking the months ...
of summer will be a better time to circumnavigate Vancouver Island. I'm not aware of a website that addresses your concerns. I've been up and down the inside of the island a number of times but never the outside. Mr. Jeff Renner wrote a very good book on PNW weather. If you do not have his book I highly recommend that you purchase a copy and study it. I compiled some highlights from his book that follows:Pacific Northwest Weather Tips· If you stand with your back to the wind, low pressure will be to your left.· In the PNW, steering currents move surface weather systems from W to E.· If the low is generally to the W of your position, it is likely moving toward you.· Surface winds from the N or NW, fair weather likely.· Surface winds switching to E or SE, a weather disturbance is approaching.· Expect winds to change to SW or W with the passage of a front.· Surface winds switching from E or SE to W, expect brief clearing, but be prepared for the possibility of showers or thundershowers.· Pressure change over a three hour period: o .6 - 1.2mb. No action. Monitor sky, wind directions and speed. o 1.2 - 1.8mb. Watch sky carefully for thickening, lowering clouds. Is the wind increasing, shifting to E or SE? o 1.8 - 2.4mb. Same as above. Consider finding safe harbor due to possibility of high winds. o 2.4 - 5.9mb. Seek safe harbor immediately. Gale force winds likely. o 6.0 - >6.0mb. Storm force winds likely. Seek safe harbor immediately.· When cold air sinks, air pressure increases, and decreases when warm air rises.· Air generally moves from an area of high pressure to one of low pressure.· When air cannot hold any additional water vapor, it is saturated, or dew point.· The dew point is always equal to or cooler than the air temperature.· As air cools, its capacity to hold water vapor is reduced. That which spills out condenses into a cloud of water droplets.· Clues to a warm front: o Look for approaching clouds from the SW, W or NW. o Look for flat, sheet like stratus clouds. o Look for thickening, lowering clouds. o Look for surface winds from E to SE. o Look for a gradual decrease in air pressure. o Look for an increase in air temperature after warm front passes.· Clues to cold front: o Look for clouds to thicken, lower, merge and darken. o Look for winds to increase, usually E or SE. o Look for drop in pressure, usually rapid, then rises after cold front passes.· Radiation fog: o Moist ground from rain/melting snow, warm water. o Clearing that allows overnight cooling, late autumn early spring. o Light winds.· Advection fog: o Hot weather east of the Cascades. o Cooling temperatures and fog moving northward along coast. o Air pressure at least 2mb higher at Astoria. o Strong westerly winds. o Wind shift N or NE to S or SE.· Warm frontal fog: o Lower thickening stratus clouds. o Light E or SE winds. o Steady precipitation. o Small shredded or torn clouds close to the ground.· Sea fog: o N or NW coast winds. o Two to three days of wind minimum. o Velocities less than 25 knots. o July through October.· Steam fog: o Clearing overnight. o Light winds. o Air temperature cools to below surface water temperature. o Autumn and early winter months.· A wind shift from N or NE to SE signals an approaching low.· A shift from SE to SW signals the passing of a low.· A shift from SW to N usually indicates a building high pressure system.· Weather plan two days before trip: o Check overall weather pattern. o Check projected weather next two days.· One day before trip: o Check current weather to evaluate accuracy of previous day’s forecast. o Check overall weather pattern. o Check projected weather for next two days. o If high winds, thunderstorms possible, check updates every six to eight hours.· Day of trip: o Check current weather to evaluate previous day’s forecast. o Check projected weather for trip. o Make go/no go decision based upon current forecast, the track record of earlier forecasts, your personal experience, experience and comfort level of your crew, and the capabilities of your vessel.
