I know this is a well-worn topic, and that I will get a flurry of links from Stu Jackson, but I have a very specific question, narrowing the topic quite a bit, and I would really like to get Mainesail's view on this.
I think I'm making water through the keel bolts on my 1984 Catalina 36. Once, about 10 years ago, I torqued the nuts to 105 ft-lb. I haven't since, and the water increase is recent.
I've read everything I can find on the topic, with remedies from removing the keel and re-bedding, to simply tightening the nuts; in or out of the water is debatable.
One thing that has a lot of appeal is to remove the nuts one at a time, applying some kind of sealant, and then replacing and tightening the nut. The generally recommended sealant is 3M 5200 (yes, Satan's glue).
I'm inclined to try this while in the water, having dried the bilge as well as I can, observe any water entering, but probably do all nuts, one at a time.
Here's the question: what sealant? 5200, 4200, flax packing, butyl tape?
