Sealing the Hatch Slides
Tim
Has anyone tried to reseal the teak hatch slide guides? I have noticed after our latest batch of heavy rains some of the old caulk washing out from under the wood. It seems like the only way to do this right would be to remove the teak all together and reseal. How is this done? Can you unfasten from underneath or do you have to drill out the plugs to get to the fasteners? Or can you effectively seal the area without removing everything? Tim
Russ Smith
Stuck Hatch
Hi Tim Did you find out anything on your question? My hatch is stuck, it will only open a couple of inches....I'm thinking I will need to remove the thing to remove any obstructions. russ
