Jim
I need to remove and re-bed the four non-opening ports on my "new" '79 O'Day 25. This looks like a pretty straightforward project. The inside trim has a number of screws around it's perimeter. The outer trim "rings" seem to be in two pieces. Anyone out there that has taken these apart and would care to share earned wisdom? Specifically:1) Does the inside trim screw into the outside trim, or just into the fiberglass with the outside being held on with the silicone bedding?2) Any "trick" to taking these apart? (Without breaking them, hopefully!)3) Any suggestions on cleaning up the plexiglass? Or should I just plan on replacing it? When I brought the boat home I didn't think this was a question at all. They were so hazy I thought they were shot. However, after liberal application of the pressure washer the majority of the hazing actually washed off (along with the other inch of crud that had turned a pretty nice little boat into a $2,000 "as is" deal.)Any thoughts would be appreciated, as is this forum, what a great resource! Thanks.
