AGMs are a good buy
I would have to disagree with the previous post on the worth of AGMs. Yes, they are more expensive than lead acid, but not by too much. Especially when you compar that a lead acid may get you a few good years while an AGM will get you more than twice that.Also, AGMs use pretty much the same charging voltage and charging cycle, don't need to be equalized, and withstand deep discharges much better. They also recharge quicker and you can get many more cycles out of them. AGMs are great for applications where the batteries may not be fully upright as they do not leak or discharge very much.AGMs can be a good buy when you think long term. Golf Cart batteries are the best for price, capacity, and durability. However, they are still lead-acid and require the same care. Also, since GCs are six-volt, you will need two in series to get 12 volts. Two GCs are the same size as a 4D and combined about as heavy.Make sure you analyze your power needs before making this decision. Also, look at upgrading your charging system to a high-ouptut alternator and smart regulator. Those will help you keep your batteries healthier longer.Good luck,Les Murrays/v Ceilidh'86 C-36 #560
