Going to replace a horn cleat used for the jib furling line on a '87 Hunter 28.5. The cleat is thru-bolted so it doesn't need much adhesion (eg 5200) but I'd like suggestions for a good sealant to use between the cleat and deck to prevent water leaks thru bolt holes.
Thanx
Thanx
