Sealant on garboard drain plug
Jun 4, 2007
117
Gulfstar 37 Noank, CT
A bit early, but already thinking of Spring commissioning.
What sealant, if any should I put on the threads of the garboard drain plug when I reinstall it?
I'm thinking of teflon plumbers tape, but wondering if something more robust should be used to prevent any back off?
TomY
Alden Forum Moderator
Jun 22, 2004
2,769
That's what I use or a teflon pipe dope sealant. Tighten it up snug, don't over do it, you could turn the whole body or gall the threads. I've never heard of a garboard plug backing off and they are used pretty universally around here.
Dec 23, 2016
191
Catalina 27 Clinton CT
X2
I worked in a boat yard for years. We never used any sealant on them. The threads are pretty fine so a quarter turn with a wrench and you are good to go
Likes: TomY
Jun 4, 2007
117
It's our first boat with a garboard drain.
Thank you all for the reassurance and advice.
Likes: TomY
capta
Jun 4, 2009
5,100
Ours is bronze so we just put it in and it seems to come out easily enough when the time comes. Never heard of a bronze one backing out, even in a grounding.
