Sealant for replacing handrails and such
Robbin
I will be removing the handrails and other wood trim for refinishing. When I put them back on, what kind of sealant do I place between the boat and the wood to keep the holes from leaking into the cabin?
John Visser
3M 101
On wood, need to seal it first using varnish or 3M primer.
L
LaDonna Bubak - CatalinaOwners.com
4200
You can also use 3M 4200 or LifeCaulk. LaDonna
C
Campy
Sealant
Watch out for permanent sealant. When 3M says its permanent it is! you'll not be taking the sealed peice off without some of the boat comming with it. Campy
