Seal for fresh water tank cover
Rafi
Can somebody recommend a good way/material to reaseal the cover of the original fresh water tank? (under the the aft berth) It was a nightmare to remove it, and I am looking for some material/seal so it will be easier next time. Thanks.
Dec 2, 1997
9,011
- - LIttle Rock
I'd make a rubber gasket and secure with screws
But silicone is an acceptable sealant that won't leech any toxic chemicals into your water.
Dec 2, 1999
15,184
Ready to do it too.
Rafi: I am in the process of doing that exact thing on a H'31. I will take pictures. I am planning on removing the lid (yes it is a PIA). Then I will fill all of the existing holes in the molded tank (not the lid) with Marine-tex and redrill them. I have ordered some butyl rubber 1.5 inches wide that I will make a gasket with. I plan on using some type of sealant and will reset all of the screws.
Rafi
Rubber gasket
Thanks Where can I get this rubber strip for the gasket? Did you order it online? What is the proper term/name for it?
Droop
3M 4200
Don't use 3M5200 unless you never want to take it off again.
Steve D
Butyl Rubber !!!
The product is "butyl rubber". I ordered 20' (probably 4-5' more than I needed). The company is Gardico Inc. in Seattle (home of the HOW Web Site). Their Part id was S48RX-0111-604 Strip 60D Butyl 1/8" x 1-1/2" 1/8" thick x 1-1/2" wide. The cost is 2.12/ft The total was $50.93 including shipping. Their phone numbers are 206/283-5850 fax is 206/283-4625. If you reference invoice 76926 they should be able to duplicate the order. The contact is Ron Estes. I will be installing this on the weekend after the holiday. I will try to take some photos to show the process.
