Seacocks Open or Closed while sailing?
YVRguy
Jan 10, 2013
479
Hunter 34 Vancouver, BC
Curious as to common practice, particularly among Hunter 34 owners. I was advised by the previous owner to close the seacock for the head while under sail and possibly the sinks as well. The obvious reason being to prevent backwash from coming up into the cabin.
I occasionally take the time to close them but I don't seem to have much of a problem if I leave them open. What do you folks do?
Some boats have different "conditions" than others. For example, the Catalina 36, a great "buddy" boat like ours, has a forward head and head sink. When on port tack the head sink is reported to fill with water unless the seacock is closed. We have a midships head on the port side, never had an issue.
Head inlet: all manufacturers have (or should have) placed a warning to close the head seacock after the head is used. We never do, and have never had a problem in 15 years.
We open all our seacocks (except the head out - we use the holding tank) and close them all when we leave the boat.
Your boat, your choice.
Nodak7
Sep 28, 2008
1,256
Hunter 41DS Punta Gorda, FL
As Stu said each boat is unique. When we were well heeled to Starboard the sink in the Head would fill on our 33. This boat no issues. Only close the seacocks when in Port.
RichH
Feb 14, 2005
4,773
My practice:
On long distance passages and ocean travel ---- all seacocks are closed; and, bilge is inspected ~hourly and even that I have a 'high water' alarm).
Storm conditions - all seacocks are closed (except seacocks for bilge pumps).
Inshore - all open, as I can always run the boat up and hard aground onto a shore if absolutely need to.
Mark48
Mar 1, 2008
166
Hunter 34 Milwaukee
We have had the unpleasant experience of having our head fill on occasion and thus close that and all other seacocks except for motor cooling water. If a sink needs drained it can always be opened and reclosed.
Jan 12, 2011
930
Hunter 410 full time cruiser
different boats different needs, I never shut them on my current boat
but my last boat when on stbd tack the head would fill up, so I installed a separate ball valve in the line next to the head so it could be shut to prevent it
the last thing I would want to have to do each time is get to a seacock just to take a pee :doh:
Mulf
Dec 2, 2003
400
Hunter 410 Chester, MD (Kent Island)
Close every thing but engine thru hull...
...when moving the boat. Our forward head has thru hulls about 5 feet from the bow. Imagine the water forced into that thru hull and the hose attached to it when you go airborne over a wave and come slamming down the other side! I'm not interested in testing the strength of the hose or the two clamps that way. The rest of the thru hulls on our boat are behind the keel so probably much less worry, but we close everything not in use, so there's no worry. As to Don's comment about being able to use the head, I installed a freshwater tank behind the aft head so it can be flushed without opening a thru hull. Other solution would be a bottle filled from the sink for flush water.
Nov 6, 2006
10,118
YVR.. I don't close the seacocks on my 34 when at sea.. I haven't had a problem in the 22 years I've owned and sailed her.I do carefully inspect all the hoses and hose clamps every year. I do watch the head to make sure that the flush and vent valves are working correctly. I also check things like the sink connection to the drain hose. The tee on that hose and the hose end on the head sink are tied with light line so that if the carbon steel sink outlet breaks off, the hose cannot fall below the waterline. The only time I close the seacocks is when preparing for a hurricane.
Jun 4, 2004
109
Hunter 38 Pentwater MI
I guess it depends on just how much you believe in Murphy's Law. It is a pain but can't hurt to close them - just make sure you open the raw water valve for the motor!
splax
Nov 12, 2012
694
Hunter 34 Portsmouth
Personally, I am comfortable with the sink drain through-hull valves open underway, but I suppose there is the chance of a hose failure. The head may fill with water if the switch is not in the dry bowl position, so I keep the through-hull valve closed underway if not in use. If sailing, I may close the raw water engine cooling valve if it is rough. Head discharge always stays closed.
7,190
CC 30 South Florida
Easy, run your boat with the seacocks open; if you do not detect a problem on either tack you may choose to leave them open. Inspect your hoses and clamps at frequent intervals for safety concerns. I only close them when the boat is left unattended as the electric convenience bilge pump will not be able to keep up if there is a significant failure.
Dec 14, 2003
1,442
I generally keep them opened and have not had any problems except for some gurgling from the forward vanity sink drain when on a hard starboard tack. Also with guests aboard I need to make sure the lever is in the dry bowl position as the bowl itself is 2 inches below the water line and if overfilled it willl sink the boat! I was lucky to be awakened in the middle of the night by the sound of the bilge pump running non-stop. A quick check showed the lever had been left in the wet position by a guest who used the head during the night. So I now close the through-hull seacock during the night and ask guests to pour water in the bowl when flushing. I have had 2 dock neighbors sink because of faulty hose clamps. So I make it a habit of closing all seacocks (including engine intake) when away from the boat. I leave the key on the engine seacock so I cannot start the engine and have it run dry.
