Seaclear II
RECESS
Dec 20, 2003
1,509
Catalina 27 . St. Mary's Georgia
I have been running this program for over a year and use it along with my chartplotter on board. I use a usb GPS dongle with it. I doubt I am using 10% of it's capabilities. I would love to hear from people that have figured out how to use it for different functions. I would love to be able to import way points form another file, even if it means reformatting the file? I also do not know where it is storing the way points I have entered on my computer? I use it to back up my chartplotter.
Any Seaclear II gurus here?
higgs
Aug 24, 2005
3,736
Nassau 34 Olcott, NY
I use Sea Clear, but do not know how to exploit it's capabilities. I'm happy to know where I am and where I am headed.
Sumner
Jan 31, 2009
5,254
Dave if you are trying to send waypoints from your chartplotter to SeaClear then maybe this is what you need....g7towin software. Google it and also look in the SeaClear Manual under the "Technical Information" and then "Using G7toWin to communicate with GPS".
Sorry, but that is as far as I can go. I haven't tried that. We do use SeaClear on the boat and it took us over 400 miles around the south end of Florida with no problems. We love the program and run it on a dedicated small 12 volt computer I made....
http://purplesagetradingpost.com/sumner/macgregor-navigation/Compter-Nav-index.html
...that uses less than 3 amps and we run it all the time while underway and plot all of our routes on it before starting on them. It is always connected to a handheld Garmin Map 76S in the cockpit and we can easily send the waypoints from the computer/chartplotter running SeaClear to the Garmin and we use the Garmin in the cockpit to go waypoint to waypoint.
If we are in a tight or complicated channel then I move forward in the cockpit where I can see the ....
...monitor in the cabin and give Ruth directions on where to go.
It is very accurate and easy to use under these conditions.
I've never tried to send waypoints to it though, but it looks like that is covered in the manual if you can wade through it. On our computer if you go to C:, then 'Programs', then 'Seaclear', then there are folders and one is 'routes' and another 'waypts'. I can see our routes in the 'route' one, but don't know the formate of the files themselves. Sorry I don't have more.
When we bought the Endeavour I moved the computer over to it and we will use the same system as we did on the Mac, explained above, for navigation there,
Sum
Our Endeavour 37
Our MacGregor S Pages
Mac-Venture Links
