My 10 year old boat is on the hard for the winter. The mast is down on saw-horses and I am replacing all the wiring and reconditioning my in-mast furler. There were some things attached to the mast and furling drum that were attached w/ aluminum rivets. I believe that if this project is ever done again (by the next owner), it would be easier if some of these parts were attached with screws rather than rivets. Is aluminum too soft to tap for screws and do I need a tap/die set or will self tapping screws thread their own holes?Also, I used pretty heavy "boat wire" for the electronics. I need to splice the common wire for the anchor light, steaming light, and deck lights together inside the mast and remove the other wires from their protective rubber casings to achieve a fit for my four wire connector through the deck. What would be the best way to establish a new protective casing for the four 16 ga. wires where they leave the mast and connect to the connector?
