Screw/bolt size question
Apr 24, 2006
868
Aloha 32 Toronto, Lake Ontario
I plan to use bolts to mount my 18 inch Raymarine radar to the mast.
The Scanstrut mount came with rivets that require a 3/16 hole. Number 10 screws seem to be the closest in size (I plan on using 10-32 and tap the holes).
Question - although there will be 12 screws, they seem small in size. Do I need to upsize to, say, 1/4 inch?
I can find many posts about using screws vs rivets but nobody mentions a size.
Thanks.
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
Don’t be overly concerned about the clearance hole size in the Scanstrut mount. use a screw that fits through the mount holes and drill and tap the mast for that thread size. By the way, the holes in the mounting bracket may be metric for whats its worth.
Apr 24, 2006
868
They are metric.
10-32 is a close fit for the mount holes so I'll use that size. There are 12 screws so I'm sure it's sufficient.
Oct 24, 2010
2,405
Hunter 30 Everett, WA
I imagine 12 of them are more than adequate. How many #10 bolts would it take to hold you up?
Ken
Mar 26, 2011
3,955
Corsair F-24 MK I Deale, MD
Thanks.
You can look up the strength and WLL with Google. Screws and rivets are not that different, assuming the mast is >0.1-inch thick, which I'm sure it is (I've lab tested both on masts).
This report was based on that size range, in spars, and included both sheer and tensile testing.
https://www.practical-sailor.com/issues/44_9/features/A-Riveting-Report-Spar-Fasteners_12480-1.html
There is nothing wrong with rivets, if installed properly. They are just as strong as machine screws. What ever you chose, do it neatly, and use Tefgel or equivalent.
FWIW, the sheer strength on these fasteners is about 1000 pounds, tensile, about 1/2 that. Also, 10-24 will be considerably (25-40%) stronger in tension in a soft metal, like aluminum, at typical spar thicknesses. Shear will be about equal. Just sayin', based on testing. A fine machine screw is much weaker in pull-out strnegth, in thin metal, than a proper rivet. Counter intuative, perhaps, but proven.
868
Interesting.
My mast specs at .125" thickness. So 10-24 would be stronger (in pullout) than 10-32?
I'm not a Practical Sailor subscriber so I can't read the article but thinking I should be.
May 20, 2016
3,015
You might look at using rivnuts rather than drilling and tapping. It will be stronger and easier.
Les
Mar 26, 2011
3,955
Interesting.
Yes, fine threads are stronger in steel, but coarse threads are stronger in thinner aluminum. Below about 0.125, rivets are better than either. Think of what Hobies endure, using nothing but rivets.
FWIW, self-tapping screws are never the right answer in a mast, if for no other reason than because the sharp points will snag lines and cut wires.
