screaching sound while motoring
JohnJ
May 4, 2008
4
Catalina 310 Fairhaven
I have been getting a screeching sound while motoring. I just bought a 2001 Catalina 310 and had to motor 6 hours and it made the sound once. Yesterday I motored for about an hour and it did it 3 times. I was cruising at 2000rmp and when I cut back the throttle, the sound stops. I then increase the throttle and it is fine. It almost sounds like the propeller is slipping. Could this be a transmission problem? Thank you.
K
Ken
Screech
If you have a PSS dripless packing it may need to be burped. It could also be the fan belt that powers the alternator. Did you check the transmission oil level? It's color/smell is the best indication of problems. It should be light red and not smell burnt. Too sharp an edge on the prop can also cause the prop to sing.
JohnJ
May 4, 2008
4
thanks
Thanks Ken. I do have a dripless packing and i haven't checked the transmission fluid. I will have to check the manual but how do you burp the driplesss?
Nov 12, 2006
256
Catalina 36 Bainbridge Island
Burping Your PSS
Just pull/push the forward (closest to the engine) end of the bellows away from the part that is attached to the shaft to let air out of the PSS. You will get some water in as well.
Mar 1, 2004
351
Catalina 387 Cedar Mills-Lake Texhoma
Water Injection
On later and larger model Catalina's, they have added a small hose from the engine water system to the PSS fitting. This is to solve the sometimes problem of a air bubble at the joint.
Jun 5, 2004
72
Catalina 27 Stone Harbor NJ
Belt tension
Check your alternator belt tension. If too loose, it could be slipping and screeching. When properly tensioned, there should be about an inch of deflection when you press against the belt. Randy
Terry
Screech
that screech might be one of the pumps or the alternator freezing up. If you can loosen the belt try to rotate each of the pullys that ride on the belt. If one is siezing then that is the problem. REplace it before it siezes altogether.
jviss
Feb 5, 2004
7,089
Tartan 3800 20 Westport, MA
Moderators?
You have two threads going for the same topic, one with 6 replies, the other with eight.
