Schafer Outrageous Pricing
jviss
Feb 5, 2004
7,090
Tartan 3800 20 Westport, MA
don't expect plastic to last forever but when it does fail, I expect a fair price on the replacement or on the parts to repair it.
Ha, that's funny after 37 years. You're lucky they are still in business!
jviss
Feb 5, 2004
7,090
I ponder that Harken subsidies them secretly so that Harken can maintain higher prices, albeit really driven by their significant R&D budget. :)
My boat is just about all Harken hardware: blocks, winches, clutches, etc. They are not perfect, of course, but no one is. I have found my Harken hardware to be really good, and Harken customer support to be nothing short of superb. They have even consulted with me for Harken things I have purchased used, and have one more than one occasion sent me things for free. I had experts consulting on and explaining product specifics, like strength and application. I'm sold.
Likes: Timm R Oday25
dLj
Mar 23, 2017
4,763
Ha, ha! Wow, you have a dozen of those stanchion blocks? That seems like a lot. I. think I might have - four? - on a 38 foot boat. You said "a couple" in your post. For a dozen, on a 40' boat, you'd have to have stanchions spaced maybe 2' apart from cockpit to bow! Wow.
For me, I now have more more time than money, so I wouldn't count time spent searching for stuff. :)
You didn't read my original post well - I said a couple had broken, but thought to replace them all.
I have two roller furlers as I run a cutter rig. Rethink your math. I have a roller furler line on both starboard and port sides. While I have a 41 foot boat, I also have a bowsprit, so that adds distance for the roller furler lines to run. So you have 4 on your 38 foot boat. I have a 41 foot boat with a bit more than a 4 foot bowsprit. Think about it...
If Bacons were closer to me, I'd go hang out there instead of seeing a movie... ;) The other day I was there with my brother and it was his first time there. He walked in and said, "OMG, this place is REALLY dangerous. Look out for your wallet...." We were there getting the blocks for my staysail. The staff there is very knowledgeable and helpful. I first went in with my calipers, rule, and the two blocks I needed to replace. I first went through their used equipment section without success. One of the guys working there saw me and asked if I needed help, I did. He then spent probably a good hour, or maybe longer, going through all their display parts, (I'd exhausted the used section) then through all the catalogs. The catalogs yielded nothing. Then we found one of the display blocks and could measure various bits and finally found a solution. This is not the first time Bacons has "done me right"....
dj
jviss
Feb 5, 2004
7,090
It wasn't clear to me that "all" was a dozen. You never mentioned a dozen. No matter. Glad you found a solution. But why replace the ones that hadn't failed?
dLj
Mar 23, 2017
4,763
Because I'm not just coastal cruising or day sailing. The ones that hadn't failed were still exposed to the same time/conditions as the ones that had. Clearly the reason for their failure was UV damage to the polymer pulley. So how much longer do the others have before they also fail? Now, if I'm 4 days off shore and the stink is coming up, do I really want to worry about my roller furling systems?
dj
jviss
Feb 5, 2004
7,090
dj
Yea, good point. Preventative maintenance. Would have been cool to make new sheaves, eh? I did that, using Starboard, when I had a big lathe.
dLj
Mar 23, 2017
4,763
I thought about that. But the originals were riveted together, not bolted, and they had delrin bearings. Not something I'm going to reproduce. The entire block was not manufactured with remanufacturing in mind.... They are quite nice blocks actually. If I hadn't had another more economical option, I would have bought them again without hesitation.
By the way, Starboard is HDPE. Now I don't know if the Starboard manufacturers put UV resistant filler in their product, but HDPE is not a UV resistant material. Without knowing their formulation, I will use starboard only in locations that are out of direct sunlight. But that's me... For parts that are going to be exposed to full sunlight, I'll use UV resistant delrin.
dj
jviss
Feb 5, 2004
7,090
dj
Interesting point. I have some Starboard exposed to the sun for over 20 years, still looks OK! :)
Starboard has UV stabilizers:
UV STABILIZER AND COLOR STABILITY OF KING STARBOARD®
dLj
Mar 23, 2017
4,763
Nice! That's useful.
I do note that they say 8 to 10 years for mechanical properties. That's pretty good. I still prefer to use an inherently more UV stable material than HDPE. But this is very good to know.
Is King Starboard the only manufacturer of Starboard?
dj
Sep 24, 2018
3,994
Catalina 30 MKIII Chicago
They use plastic with excellent UV resistance but I agree, they are very overpriced and half of their blocks dont even use ball bearings. You can get another name brand block with bearings for less
