I'm getting air in the fuel line of my Yanmar SB8 diesel. It has been getting progressively worse through the summer -- to the point that I have to bleed the system if it sits overnight. I can't see any obvious fuel leaks. Is there a check valve I should be checking?Also, while reliable when running, this motor can shake the fillings out your teeth. Has anyone changed motor mounts? Does it help?Thanks.
