save that caulking
John
Jun 3, 2006
803
Catalina 36mkII Alameda CA
Ever get frustrated buying a tube of caulking for just one or two applications and then find you can't use it anymore when you go back to use in a month later? Maybe everybody else already knows this trick, but what I've taken to doing is running a long screw down the nozzle and leave it in when I'm done using the tube. After even several months, I can still use the caulking (even though I mostly use butyl tape as suggested here on this forum).
Ross
Jun 15, 2004
14,693
Like everything else here it depends. In this case it depends on the type of caulk. 5200 will cure in the tube all the way to the bottom if you leave it long enough.
7,743
Alden 50 Sarasota, Florida
Just read in one of the sailing mags the hint to also store it in the refrigerator as cold often slows the curing time in the tube.
Manny
Oct 5, 2006
983
Hunter 82? 37 Cutter Wherever the wind takes me
Store it even longer in the freezer.
I've been able to store opened 5200 for a year and still use it, same with 4000.
If unopened the fridge is good. I keep my unopened caulk next to my rolls of film!
Manny
If that is an issue, then simply
buy smaller tubes of it, like the size of toothpaste tubes, at Ace Hardware.
I agree with John, and also stick screws in the long tubes and leave them down low in the boat, can usually get most of the stuff out.
Joe A
Feb 4, 2008
117
Macgregor 26S Lake Wallenpaupack / EastCoast
I use a vise
For tubes with flexible nozzles like silicone I clamp the end of the nozzle in the vise in my garage. The plastic to plastic seal will help the contents to last a really long time. If I periodically need to use the vise I can temporarily remove the tube and then put it back when I'm done. This probably won't work for 5200 due to the screw on nozzle.
Jan 3, 2009
821
Marine Trader 34 Where Ever I am
If the tube does set up it is usually just a short length into the nozzle. Use a drill with a bit just smaller that the hole at slow speed and it will pull out the hardened caulk and you will be good to go.
77
Macgregor 25 Naples, Fl.
I have found that if I remove the nozzle from the tube and clean it out with acidtone and then place a small piece of alum. foil over the threaded end of the tube before replacing the nozzle that the 5200 will last for months.
higgs
Aug 24, 2005
3,738
Nassau 34 Olcott, NY
I store my tubes with the nozzle end up so that the caulk drains back into the tube. that seems to help some.
Ross
Jun 15, 2004
14,693
Some of the caulks that I use will keep in the open tube for weeks and others harden in just a few days. I have had pretty good success with long drywall screws as stoppers because they seem to drag the hardened caulk out when I pull the screw. Construction adhesives and urethane and silicone caulks go bad after anywhere from a few days to a few weeks. I just count it as part of the cost of the job. If I hired someone to do the same job it would cost more than a tube of caulk.
