Sanitation Vent
56
Oday 27 Ottawa,Il
The holding tank and head on our boat has been replaced by the previous owner trying to reduce odor. The vent line is way to long with loops and bends. I would like to reroute the lines and cross ventilate the tank as advised by Peggy in her book. (I would recommend this book to anyone.) Does anybody know where I could find the larger 3/4" or 1" deck vents? Thanks Ron
T J Furstenau
Standard Thru-Hull
I also followed Peggy's advise with larger vent lines when I replaced my holding tank. My old vent was high on the starboard side. I just drilled it out to fit a standard 1" thru-hull. Vents great, is well above water line, makes a great way to simultaneously flush the tank while pumping out, which also insures the vent line stays clear. And no covers for bugs and spiders to build nests under. T J
Dec 2, 1997
8,966
- - LIttle Rock
"Vent" thru-hulls only come in one size...
'Cuz 5/8" is the "standard" size for water and fuel tanks, and all "vent" fittings are designed to be "one size fits all"--water, fuel, waste. So you have to use a bulkhead fitting as T.J. did if you go with a larger waste tank vent. And as he said, an open bulkhead thru-hull makes it a LOT easier to flush out the vent line. Glad you find my book useful!
