I am preparing to replace my entire sanitation system - head, hoses, and holding tank. I am planning the project so I'll have all the parts I need before I get started. I've received help from many of you, including directions and pictures of a holding tank replacement project. But I still think I'm missing some piece of the puzzle of my understanding of how the H30 system works. Here’s what I’m thinking. Correct me where I’m wrong.The seacock to port, aft under the aft berth is the inlet for the head. (To starboard is the raw water inlet for the engine. To port, forward under the aft berth is the discharge for the head.) Water flows out of the seacock in a ¾” hose and runs somehow until it gets to the bulkhead behind the head; it comes thru a hole in the bulkhead to the toilet. [Does this hose need replacing, since it’s only freshwater, not waste?] Water goes from supply hose into pump mechanism and out again to the toilet, all right there at the toilet. [This is where I need a vented loop installed – between the pump and the bowl? Where to install it? In the compartment in the bathroom counter with a lid and a shelf inside - but not tall enough? Or the compartment aft of the toilet? How to access that one? With the shower seat, I don’t see putting on the bulkhead directly behind the toilet.] Waste and water go into the bowl and out the 1 ½” hose on the back of bottom of the pumping mechanism, then mysteriously disappear thru a hole in the bulkhead directly aft of the toilet
And here’s where I get lost, but I’ll take a stab at it . . . The 1 ½” discharge hose dumps into the top of the holding tank. Another 1 ½” hose is connected to the outlet of the holding tank. That hose goes to a Y valve that allows the user to select whether to direct the waste to the dockside pump out fitting on deck or to the pump that discharges the waste overboard through the aforementioned seacock/through hull which is forward, to port, under the aft berth. [I’M NOT SURE IF THERE IS REALLY A Y VALVE, OR IF IT’S JUST A LINE LEAVING THE TANK, AND THE WASTE IS EITHER PULLED UP THE DOCKSIDE PUMP OUT OR OUT THE SEACOCK BY USE OF THE PUMP.] Also not sure if it needs any design modifications.The Rule pump that is mounted inside the stern in the port compartment has its inlet hose coming from the holding tank’s outlet hose or Y??? The Rule pump pumps waste out of the holding tank and out the through hull fitting. This hose already has a loop (not vented?) so doesn't need any modification?The dockside pump out fitting is also connected to the tank’s outlet hose or Y and is used to pull waste out of the tank. The tank also has a ¾” vent line running from the top of the tank to a vent on the port side of the hull. [Not sure exactly where this vent is, but I think that’s right.] So how did I do? The Y is the big thing I’m not sure about. I don’t recall seeing that, but I haven’t looked for it, either.My mission on the boat for this weekend is to document the entire existing system with pictures, but it's supposed to be 100 degrees on Saturday here. ugh.Thanks as always for the help!
