It depends on the fittings...
Gray PVC fittings that are nominal 1.5" thread x 1.5" barbed are actualy 1.5" thread by 1 5/8" barbed. Why? I've never found anyone who knows...and it's only true of 1.5" fittings...all other sizes, the nominal and actual sizes are the same. But that extra 1.8" diamter of the so-caled 1.5" barb makes it almost impossible to get a hose onto without over-heating the hose so much that it damages it. However, nylon and marelon thread-barb tank fittings are actual 1.5 x 1.5...the hose should slip onto those with only a reasonable amount of effort if you warm it a bit with a blow dryer and lubricate with dish soap, or better yet, K-Y. Do NOT use vegetable or any other oil or grease that remains slippery...the fitting can work it's way off again. Dishsoap and KY are water soluble lubricants that dry out and do not remain slippery.
