We appear to have reached the point where our main sanitation hose has become permeated. Has anyone replaced this hose and, if so, are there any caveats to be aware of? Doug.
As long as you're gonna replace one hose, replace 'em all. Use Trident 101 or 102 for 1" and 1.5"... the sbo.com online store has it for a VERY good price! Use Trident or Shields #148 for vent line and toilet intake.
[FONT="]1.[FONT="] [/FONT][/FONT][FONT="]Measure the amount of new hose you’ll need and buy it (add at least one extra foot as a safety margin). Use sanitation hose throughout the entire system, including the toilet intake and tank vent.[/FONT]
[FONT="] [/FONT]
[FONT="]2.[FONT="] [/FONT][/FONT][FONT="]Pump out and rinse out the holding tank VERY thoroughly. Adding Raritan C.P. to the rinse will remove most of the odor. Rinse out the entire system—the head, any macerators or manual pumps, and the hose VERY thoroughly—with lots and lots of clean water, followed by about a gallon of undiluted white vinegar. (Vinegar is highly destructive to rubber and neoprene, so make sure to rinse the vinegar completely out of the toilet unless rebuilding the toilet is included in this project). If the hoses REALLY stink, it helps to smear a healthy glob of Vicks Salve under your nose before you start; a cool day also helps. [/FONT]
[FONT="] [/FONT]
[FONT="]3. Map out your entire plan and determine solutions to all problems and obstacles before you remove a single hose.[/FONT]
[FONT="] [/FONT]
[FONT="]Now you’re ready to start work:[/FONT]
[FONT="]Remove the highest hose connection first to minimize drips, and stick plugs (available from any hardware store) in the ends of the hose. Work on only one hose at a time...and take each section of hose all the way off the boat as soon as you get it loose (your dockmates may insist you take it all the way off the dock!). When taking a hose off a fitting, have a pan (disposable aluminum pans are good for this) under the connection to catch the drainage. Have lots of rags handy to mop up what misses the pan. [/FONT]
[FONT="]Removing hoses becomes much easier if you’ll heat them with a blow dryer to soften them up before trying to work them off. Unless you want to also replace all the fittings, do not pry them off with a screwdriver or saw them off...the screwdriver blade will dimple the fitting, the saw will cut into it, and the new hose won’t seal. [/FONT]
[FONT="]It’s often much easier to pull new hose through inaccessible places if you connect it to the old hose and pull the new through as you pull the old out. Use a male-to male connector...use PVC cement to "glue" both hose ends onto it. Do not use hose clamps or duct tape...hose clamps can get caught in an inaccessible place, duct tape will not keep the hose on the connector if you have to pull hard. Be sure to butt the ends of the hose tightly together to create the smoothest uninterrupted surface possible. After you’ve pulled it through, cut the new hose cleanly behind the connector. [/FONT]
[FONT="]To put the new hose onto fittings, WARM the hose with a blow dryer (use a heat gun only if you really know what you’re doing with one) to soften it. Be careful, and be patientl! You only want to soften the hose enough to slide it onto a fitting; overheating hose can damage it, causing collapse or tearing. Smear a little dish soap (or even better, K-Y surgical jelly) on the inside of the hose and the outside of the fitting to lubricate the connection. Don’t use Vaseline or any grease...and don’t use ANY cement or sealant...only Teflon tape on the threaded end of fittings. Double clamp all the hose connections.[/FONT]
[FONT="]NEVER heat a hose to make it bend tighter than it wants to bend willingly! Doing so will damage the hose and/or result in a kink. Instead, break the hose and use an inline radius fitting.
[/FONT]
[FONT="]Plastic tank fittings are NPT (National Pipe Thread) standard, which are slightly (so slightly that it’s not noticeable to the naked eye in such a short piece) tapered. They’re also self-sealing. So when threading fittings into the tank, tighten only one turn past “hand tight,” plus enough to aim an elbow in the direction needed, no more. Over-tightening can result in a cracked tank. [/FONT]
[FONT="][/FONT]
