Sanitation hose recommendation requested
Jun 1, 2009
1,856
Hunter 49 toronto
I just ripped out ALL the sani hose on my 49. Miserable job!!
So, I’ve got to make choices on what to replace it with.
I need both 1” and 1-1/2” sizes
I’m looking at both Raritan & Trident
Need something that flexes easily, and will also fit over barb fittings.
All of my original hose was permeated, and the smell was getting noticeable once you lifted up floor boards.
Btw, I’ve come up with a few good tricks which I will post after the job is complete.
Hopefully, our patron saint “Peggy”, will chime in on this
Jan 7, 2011
5,794
Oday 322 East Chicago, IN
My experience is that Trident is not flexible.
Someone recently told me that Raritan Saniflex was the easiest he has ever used (I have not used it, but a good reference).
Greg
Dec 25, 2000
5,948
Hi Art. Replaced our blocked aft head discharge hose with this product: Raritan Sani / Flex Sanitation Hose
Easy to work with and very flexible. Did a post awhile ago about the project and had several replies. That post is here: Clogged Sanitation Hose
A bit different issue than yours, but the post offers several problem solving ideas.
1,152
Hunter H30 1982 Chicago IL
I used Shield’s sanitation hose from West Marine. Warming it with a hair dryer or heat gun softens it for both bending the hose and sliding it over hose barbs.
Jun 1, 2009
1,856
Hunter 49 toronto
I believe that the existing hose I gave is Shields, and it started to smell 2 seasons ago. Thought it was a system leak at first, but it ended up being stinky hose. I’ll look into it though… thanks !!
Nov 6, 2006
10,134
I did mine with Santi Flex and I am very happy with the stuff so far. PO had used a "chemical rated" hose and varnished (or some kind of rubber paint) the OD of the hose to hinder permeation. It lasted about 25 years. The Sani Flex is expensive, but the stuff is easy to work with.
Dec 2, 1997
8,988
- - LIttle Rock
Raritan SaniFlex is the top rated sanitation hose for two reasons: it has a 10 year warranty against odor permeation and it's so flexible that it can be bent almost as tight as a hairpin (3.25" separation in a 180 degree bend) without kinking...making most re-hosing jobs a LOT easier. Available in 1" and 1.5"...Defender has it for about $10/ft and sell it by the foot (many retailers only offer 50' coils).
"Saint" Peggie
:plus:
@Peggie Hall HeadMistress had on multiple threads identified Raritan’s Sani-flex hose as the best product. It scores on two key issues. Ease of install and denial of smell by permeated hose odor.
If these are your concerns then buy the Sani-flex. Defender has in the past been reported a good source.
Likes: Leeward Rail
Jul 7, 2004
8,497
Hunter 30T Cheney, KS
:plus: for Saniflex.
Did you happen to use messenger lines or is your hose routing easy to pull new hose?
Mar 4, 2019
140
Hunter 40.5 Baja
Just replaced all hoses and used both trident and saniflex. Both are reviewed positively but it's certainly true that saniflex is very flexible. If I redid the job I'd use all saniflex.
Dec 25, 2000
5,948
Hi Justin, perhaps the OP will reply to your message, but to your question, In our case I used a plastic barbed butt fitting to connect the new to the old, wrapped each connection with tape, then applied a lubricant to the new. Pulled right through, a quite long route mostly hidden.
  • Helpful
Likes: Justin_NSA
Dec 2, 1997
8,988
- - LIttle Rock
Maybe SBO can create a message bot that replies on your behalf with your oft repeated answers. :beer:
You don't think I'm smart enough to create one of my own? :biggrin: It's not quite a bot...it's a file on my desktop that I do have to access and select the appropriate reply...and occasionally add and/or edit.
--Peggie
1,152
I’ve had no odor problems, but I also regularly use large doses of scented holding tank treatment and pump out frequently because my tank is rather small. Take Peggy’s recommendation over anyone else here, including me.
Jun 1, 2009
1,856
Hunter 49 toronto
I’m leaning towards this.
Good reviews.
thanks !!!
