Sandusky OH Marine Service
Tom
I recently purchased a Hunter 28.5. I need to find the best marine service for fiberglass and shrink-wrap in the Sandusky region.
E
Ed Schenck
Which and why?
Why do you need both a fiberglass and a shrinkwrap service Tom? I assume you want to shrinkwrap for the winter. At Harbor North some folks use the services of the marina for shrinkwrapping. Others contract with companies that do nothing but travel around in a van with all the materials. Either way I am sure Harbor North would point you in the right direction: 1-800-451-SAIL
Michael O'
Sandusky resource
Another resource in Sandusky: 419-625-1666 Battery Park Marine services 1231 First Street P.O. Box 578 Sandusky
H
howie
sandusky info
Sandusky Harbor Marina, right down the road from battery park marina, Steve Chaffee is in charge of the maintenance, he is very good. I know someone that got fiberglass repair there, they did a wonderful job and matched the gel coat perfectly. howie~"Freewill"
Tom
Thanks for the suggestion
Ed, Yes, I want to shrink-wrap for the winter. The rudder has a high moisture reading tha I want to have checked. Tom
E
Ed Schenck
Rudder work.
It's a nit Tom, but there is almost no fiberglass work to be done on a rudder. You have a very thin shell over foam. And moisture in that foam is very common. You can fix that yourself unless you suspect corrosion damage to the rudder stock and/or the welded on plate. That would be unusual for a freshwater boat.
